Old 10-21-2010, 09:35 AM
SuaveX5's Avatar
Fatal Error !
alternator/charging system problem
I replaced the alternator on my 2002 3.0 X5 with a new Bosch 140 amp alternator.
With the car on I get 13.7 volts, and when I turn everything you could think on I get 12.5 volts, is that normal?
The other problem is that when I accelerate very fast and the RPM hit 4k or more the battery light comes on for a ¼ of a second, but if I accelerate slow pass the 4k rpm mark it the battery light doesn’t come on.
Any suggestions?
Old 10-21-2010, 11:54 AM
amacman's Avatar
possibly the belt driving the alternator is slipping under extreme power .
if you had it replaced very recently it may need time for the belt and pulley to settle .
just my guess from your description .
Old 10-21-2010, 01:29 PM
I'd think that if it does the same thing with the new alternator as it did the old one, check the connections at: back of the alternator, jump start connection positive post, engine ground. I have seen it before where the engine ground cable (at passengers side motor mount bracket) had a funky connection and caused a poor charging output and weak starter due to lack of ground path.
Old 10-21-2010, 01:48 PM
SuaveX5's Avatar
Fatal Error !
Thanks for the reply guys, it never did that with the old alternator, the old alternator stopped working completely so I replaced and now is doing that!
I will check the tension on the belts and the connection on the cables!
Old 10-23-2010, 12:19 AM
why did you post this in the lounge?
Old 10-25-2010, 10:21 AM
SuaveX5's Avatar
Fatal Error !
I figured it would get more exposure
